Sign in to follow this
litespeedman
Passenger Is Swimming!
I have a problem with the A/C on the passenger's side. The box that holds the condenser? on the passenger's side fills up with water and then leaks. Is there a drain hose through the firewall that is plugged? There is a noise like a bunch of sand shifting from side to side when I turn corners, and the floor gets A LOT of water on it. Anyone else had a similar problem?
Any suggestions or help would be appreciated.
Jere :o
this is a total guess but have you checked the bulkhead towards the back of the engine bay as this sounds like it is full of water thus making the noise as the water sloshes from side to side .they usealy have a drain hole that clogs with leaves and dirt ,try to find it and unblock it there is one in the middle and one either side of the engine bay
wrote something - but didnt see it was for the LS oooopss!
