Prolex-uk Under Chassis Braces
Dave-Ellen
OK,
Mat C has let me copy his JAPSAI braces ..... as you may know these did what it says on the tin but were too low (rear set).
With this in mind the firm I've found will redo them in such a way make them higher.
They will be offered in mild steel or duralim (oval section)
Not sure on the price yet this will depend on the number of orders.
Could I have expressions of interest please I can then go to the supplier and get a price for ** of them. I can then get back to you all.
I've PM'd a guinea pig :winky: who will hopefully be able to try them out to make sure they are speed bump friendly.
Dave
Dave, could I please just buy the back section?
I've gor the original Japsai's sat here winking at me but I haven't had them fitted yet due to the probs with speed bumps (bearing in mind I already scrape some of them on the way to work with more than 2 people in the car!)
That will be fine your lordship....I'll be doing the same :whistling:
