Sign in to follow this
idmax
Vss Wire
Does anyone know yhe exact location of the speed sensor wire on a 2001 is200 se manual, prefereably not behind the clocks. I have searched the net and there are a lot of conflicting results. How can you test it with a multimetre, do you put it on AC or DC. Thanks
I remember Duncan saying that you can pick it up in one of the footwells,not sure which though.
Hope this helps!!
Have you seen the amount of wires in the footwells!! How do you know which one? I have found a white wire with a blue stripe on it coming out of the ecu under the bonnet, would that be the right one?
