Just driven back from Coventry and brake warning light came on about 70miles from London.
Stopped at service station checked brake fluid level and resevoir for leaks, all appeared ok. Checked wheels for signs of siezed callipers, excessive heat etc all seamed ok.
had a look in handbook and only reference appeared to suggest carrying out a 'check' rather than the 'take car to Lexus dealer' warning so completed journey
On way back listened out for any funny noises or uneven braking and all seemed ok.
I am hoping its just a warning to replace pads and have booked car in for brake inspection.
Has any one had similar experience, should I be concerned?
check the brake bulbs. Take the bulbs out and clean up the connectors - assuming one hasn't blown.
one of my bulbs go's every couple of months ,gives the same warning light as the brake fluid so as colin said probaly just a bulb
Yep, there's no pad warning sensors on mine. Low fluid can bring it on, so can the brake light warning system. Mine starts coming on just as a bulb is starting to go sometimes too, but visibly it is still working.
B)
Thanks guys.
Yep it was a bulb, had booked car into garage so have just saved at least £75!!
Now, I presume to replace the bulb the whole rear light cluster has to be removed.
yes mate four bolts from in the boot a real pain in the butt just to change a bulb
Yep those rear lights are badly designed I have to say.
Has anyone got the nut off, only to find it drops behind the carpet covering and onto the boot floor? What a pain!!
I find it easier just to pull all the plastic panels off now!
:lol:
The same happened to me the other day,Ive got a Halfords just around the corner.Without taking the bulb out and taking it into the shop with me i told them i needed a brake light bulb for my gs300.They pointed to the little book on the shelf with the bulbs and in the book it says that i need the same type as the rear fog light.This bulb has a metal bayonet type fitment.WRONG after takin the cluster out it turns out the brake light bulb is of the capless type.Is yours the same or are their books wrong?kell
Sign in to follow this
