Gs300 Mkii Sat Nav
Awais
Hello all
I have been having problems with the reader on my sat nav for some time, replacement of the reader is currenlty not an option as too expensive, unless someone knows where I can get a replacement or repair the existing.
I am thinking of replacing the touch screen and controls in the dash over to a standard dash in order to fit a aftermarket dvd/sat nav system. Is this possible or is it best to relace the reader only.
Awais
It will cost a lot of money to buy the required parts from Lexus so you would want to find a GS at a scrap yard. It probably won't be a straight swap either as the wiring looms may well be different.
What is wrong with your Sat Nav unit?
Colin
The unit will not read the cd and sends message 'no cd rom' or 'door open'. sometimes displays the gps position with a white background on the screen but no map.
All this happened after changing the old cd with a european one borrowed from Lexus library.
