Sign in to follow this
sparkyrfc
Panel Filter Or Cone?
:duh: hi how much of a difference between a replacement panel filter & a complete cone system ? .
& what 1 do u recomend
Tia
sparky :zee:
The cone system will require full induction kit but will offer better gains.
Someone was selling a Trust / Greddy system on here the other day.
Depends what you want at the end of the day, panel filter will probably sounds like stock - don't know if it affects performance (although some claim it does) whereas a full induction kit will sound different but offer more performance when done right.
How much are you looking to spend - panel = cheap, full induction & cone filter = expensive.
the replacement panel filter isnt worth the paper its made from..........
a cone filter, or induction kit is only as good as its heat shielding.....as most just suck hot air in from by the radiator.
meaning they sound nice, but perform worse than the std factory airbox
I have just fitted a complete induction kit on mine and i will never go back. the performance and noise was a lot better than i expected.
I did have a K&N pannel filter and as Supracharged-IS340 says its not worth the money.
