Sign in to follow this
aido
Removing Boot Spacer
OK, my new gear knob turned up but it doesn't fit :(
Says that the boot spacer may need removing from the leather gaiter, I've had a look and it appears that everything is one big part and is covered in the leather - anyone know how to remove the boot spacer please?
Thanks in advance
you need to prise off the chrome surround part of the console this will allow the front part of the console to be removed (the part witht he ash tray and fag lighter) you can then get access to the gaitor..
I'm in there mate but the leather goes all the way around inside - do you just cut the leather to remove or is there an easier way so that it can be put back to normal at a later date?
hmm if i recall (could be wrong though) there are some screws to remove,, but then iguess you would see that..
Paul he on about the leather gaitor for his knob.not the rubber insulator on the shaft
Aido, you cannot remove the gaitor spacer without Knacking the gaitor......
Oh $%&*!
Yes that is what I meant Mat, so that's the second shift knob I've bought that won't fit - feck!
I'm off to Halfords to get a Momo one then :(
That's the two that didn't fit!!!!
Tom's one too big so I gave it away and I've got a TRD one today p/n 33504-SP003 - the thread is too high up the knob so it doesn't fit.
I was looking at a web page and it said that the boot spacer would need removing to make it fit which made sense since it's too big :(
i have a TOMS one on my car........all you do is trim away 1/4 inch from the base.......
i had gear knobs that dont fit, but not anymore, when they did the leather retrim, they took the OEM gaiter out with that ring thing on the top of the gaiter (could that be the boot spacer you on about matey?), now without that ring bit i can fit any knobs on without any problems......
Ah Tony, that ring thing is exactly what I'm on about, I was looking at a Momo one that came with a whole new gaiter - maybe that would lower it enough?
doubt it, why didnt you just order one that does fit........... :duh:
one for the IS200 OR ALTEZZA, instead of ordering them for the Toyota Crown or Toyota Century.or such like :lol:
:o
I just asked for the MTM one for the IS300 from Carson Toyota?
forgot to say my new gaiter is not fit down at the top, which i dont mind too much about, but i suppose the Momo one should fit, just need some work to make it nice and tidy......
theres a lot of nob talk in here today :blink:
even more now you have turned up...........................Touche ;)
should be toupe with my bald bonce!
Good point - you might look like William Shatner with a toupe on mate :P
Aido mate, to get the knobs to fit u will need to trim about 7 /8 mm off the bottom of the knob, assuming its plastic u can do this easily, use a saw or if it really comes to it use a serrated knife - watch those fingers!
Aido ........if it really comes to it use a serrated knife - watch those fingers!
And your mams new Formica work top!!!
Before you progress on to do another mod.....tell me you've finished installing the HID's. :)
Pete, turned out to be a problem with one of the ballasts which I need to get replaced so they're deinstalled and it could be a while before I get the new set!
Rob, it's a leather gear knob so it will look **** if it's cut down like that :(
Going to try and get a refund - do any of you know if the IS300 manual has a longer stick than the IS200? Guess it's a difficult one as it's only in the US and they haven't seen an IS200 to compare :o
I've asked Steve Ganz if he can check whether it fits the IS300 over there or not.....
