Tyre Pressure For 18' Wheels?
luvlex
is the tyre pressure chart not printed on the drivers side door frame?
or is it just up to the 17' wheels?
some tyres have the psi printed on the side wall!
J.
It only goes up to 17".
Pressures on the side of a tyre are the maximum that tyre can take not what you should use. Each car model would have a different recommendation based on vehicle weight etc.
Tyre type: 225/40R 18Z 92Y Pirelli PZERO ROSSO
18 x 7 1/2J wheel with 225/40 ZR18 tire use tire pressures and wheel torque below."
Vehicle load up to four occupants:
Front 33psi
Rear 33psi
Vehicle loaded up to capacity weight:
Front 36psi
Rear 36psi
