Sign in to follow this
whitie
Changing Oil
On the gear box is it the star shape nut on the bottom and the Large 22mm (24mm?) nut/bolt, that are the one's for emptying and filling.
..and is it just a case of filling until it comes out? (Got a 1ltr bottle)
Ok, I've taken the above to nuts off and its come out the top one!! HELP!!!
here you go buddy this should help.................
and the data
(stunning spelling.if i do say so myself) :blink:
Cheers Matt!!
Any ideas why it came out the tope whole though???
Could it be cuz I had just been driving?
Ahh I think it may have been over filled and I've not taken out the correct lower bolt?
I've taken one more out here
only the 2 shown in the pic should be removed, the level should only be checked when cold
I managed to get just over 1.5Ltrs in there before it came over the top.. Should I try to get some more in...
Could I just say one thing... If anyone gets chapped lips put some of the above spec oil on them, it does wonders!! :lol: (ended up blowing it down a length of hosepipe!! :sick: )
Gear change feels better since I changed it.. Don't really feel the famous 1st - 2nd notch any more.
Wasn't to keen on the small metal spurs that had built up on the drain plug though!! :unsure:
I just changed my Gearbox oil too, when i poped off the propshaft during gearbox removal, although most of my oil had come out from the propshaft insert I did get the drain pug off after and drained then filled after re-assembly.
I did'nt notice any loose bits of metal, so that part relieves my mind.
I would'nt say I noticed much difference in gear change after changing the oil, but then I never had the clunking problems (touch wood) on 1st,2nd.
If the gearbox oil change fixes this, this has gotta be good news for those having the noise.
Yeap I'm chuffed to bits.
The notch feel was only there a little bit.
Though when I took the oil out the colour/texture difference in the oil made me think " :blink::sick::excl: ".
Plus the oil came out the top whole. So don't have a clue how they managed to over fill it!.
metal fillings on the drain plug are quite normal
Anyone willing to change my gearbox oil for me....wanting to use the Redline oil 75W90 see if it does really help this nothchyness
Use MT-90 rather than the 75W90 diff oil.
Is it right to say that if i wanted Lexus to change the gearbox oil after they said it may help that i hav to pay for it
Yes I would think so.
does the gearbox oil get changed as part of any of the services at lexus?
Yes I believe the manual gearbox oil is on the service schedule. But you want to put better quality oil in there to improve things not just the same again.
