Sign in to follow this
AltezzaScott
40mm Lowering Springs For The Is200/altezza
These will be ready in 4 weeks, having 10 sets shipped over initially, selling at £140 + p&p
These will go pretty quickly, so those interested, can either pay upfront, which will be refundable if you change your mind, or a good deposit.
you will need uprated Dampers with these or you will kill the factory dampers.quickly!!
whats a drop thats not gonna kill the dampers then?
30 mm - 35mm is the maximum recomended drop on springs, with factory damper, however anything over 30mm is still pushing the stroke of the piston rod in the dampers, ......
Thats the advice I got when trying to get the Prolex-uk ones sorted :blush: well fed up was I.
Something about on full drop the shortened spring may unseat itself :sick:
ah.there is that aswell, the spring becoming unseated :excl:
