Damper Part Number?
dan.walter
2000 IS200 Sport
O/S/F damper is leaking...so.....
I checked the part number of the offender 48510-53020
Lexus Bristol sold me a 48510-80143 (number on the box) but the shock inside is stamped with 48510-53041
Please help
It looks the same but i don't want to strip it all to pieces to find it is not the right one
Thanks in advance
Ok this is whats listed for your chassis.
If your old damper is marked part number 48510-53020 then your replacement should be 48510-80005.
If your old damper is marked part number 48510-53040 then your replacement should be 48510-80143.
Thanks for that Chris,
The one still attached to the car is a 48510-53020
Do you know what the difference between them is?
Will the "wrong" one they sold me still fit?
Dan
I honestly dont know what the difference is, I personally would only fit the correct one.
Well i'm glad i asked on here first..... :angry:
I called them and they said no problem....we will order the correct one for you.
So i popped in this morning and swapped it over.
It was actually a few pound more but the guy let me have it for the same price (inc Gold 10% discount :) )
I just opened the box and it looks quite a bit different.
The threaded bit on the top of the piston is much larger diameter. I would have been well pi55ed off if i had got the car all to pieces to find it was the wrong one.
So...lesson learned....don't trust a Toyota parts dude when he say's "yeah, that'll fit mate"....
Thanks again Chris....you saved me from a lot of swearing this Saturday.. :D
