Warning Light
Stu
Hi guys,
Just driving back to work after lunch, and the handbrake warning light came on on the dash, you know the one i mean, the light that comes on when you put the handbake on.
Had a quick look at the brakes, the fronts are fine, the rears look like the pads could do with changing, but i am not sure.
Can anyone help?
Bet it'll be more money needing to be spent on the car!!!!!
Stu
I took teh bulb out, checked the connections, put it back in, no warning light, brake lights worked fine. took foot off brake pedal, warning light came on again, brake lights still working.
Me have no clue.
Will investigate at the weekend, as it's dark when i get home and i don't have a light in the garage!
Stu
All bulbs are working in all 4 brake lights!
The warning light hasn't come on this morning yet, but i'll keep my eye on it on the journey home!
I'v only just replaced that bulb too!
Stu
4 brake lights??
the 2 normal outer ones and the high level on the rear shelf - do u have a spoiler with a light fitted?
