Sat Nav Disk
jasper
There are different generations of the DVD nav unit. Discs are not compatible between them. GS vehicles (and probably other models) manufactured before July 2001 use Gen 1.
The part numbers on the DVD case, the ones on the disc aren't the numbers you use to order, will increment for each revision. If the number is completly different then it won't work. e.g. for Gen 1 08664-50861, 08664-50862, 08664-50863, 08664-50864 etc.
Order your DVDs from your dealer based on the chassis number of your vehicle.
