Aristo Tv Converter
rocky v 300
Hello peeps,
After viewing the post from Skeet 94 I called Converters.tv to find out some more details, they advised that there is a converter which has A video in and video out ports and works through the sat nav auxillery wires..
Does anyone know how this would work or which wires to use?
I would have thought you use the the video in wire in the tv tuner plug it into the converter and then video out from the converter into the tv tuner itself!!
Just an assumption but does it make sense to anyone??
http://www.converters.tv/products/converte...erters/138.html
I was going to order today but thought might as well ask the almighty and knowledgeable Lexus club members!!!
Appreciate your thoughts and advise
Best regards
They are probably confused because most Lexus (non JDM) don't have a TV tuner built in. For vehicles without a TV in you would normally connect into the Sat Nav wiring.
What are you trying to do? Replace the TV tuner with one that will work in the UK?
Hello peeps,
Best regards
Yes I am trying to get the stock Aristo TV working without taking it all apart!!
Thought might as well try and get the Tv working without too much technicalities and this particular converter sounds promising,,
I am going to order it anyway and see if it works, only way to find out really and truley.
let you know how it goes
Regards
Rocky v 300
