Mud Flaps
chib1177
does anyone know how much a set of 4 mud flaps would cost from a lexus dealer. supplied but not fitted
im being lazy and impatient i know, but i could do with knowing before tomoroow when i ring the stealer.
thanks
About 49 quid, the front two are easy to fit (they use the existing screw holes). The rears require some holes drilling.
You may want to consider something to seal the gap between the bodywork and the flap too :)
*EDIT* just noticed your in North Yorkshire, I got mine from Croft Toyota, and had to reserve them as they shift quite quick when they get them in apparently... might be worth giving the dealer a call just in case.
*second EDIT :) *
Dont forget if your a gold member you may get some discount as well :) Go gold ;)
