Valet Key Only - How Does Ecu Work?
ron
I have a 2000 RX300 that I purchased from a dealership. It came with one key, the valet key. When I went to a Lexus dealership, I was told that I would have to buy a key set that costs $756. I have a friend that had the same problem and his only costs $360.
What could possibly be different that is causing mine to cost so much?
Help!
You might get a more local responce in the USA side of the forum... if it helps, my UK spec IS200 came with 2 standard keys and a valet key...
I personaly think that this should be the minimum you should have recieved with your car too.
HTH..
