Altezza Cigarette Lighter
gds
Hello all, as a non-smoker the fact that this does not work is not important but I tried to use the socket as a source of 12 volts no joy.
Question 1] is there a unique fuse as everything else seems ok
Question 2] is it easy to get to the power connections
Many thanks for any info., gds
i had this in maine a while ago - there is a fuseable link built into the bottom the the cig lighter, if that has melted then u will get no power.
u need to remove the trim around the gearstick and the remove the cig lighter and then u will see if the link is there or has melted.
Fluff, levered the lighter and ash tray out and dismantled the lighter but did not find any fusable link, where should it be.
Put a meter on the socket there was no juice with or without the motor running, help!!!! gds
the link is built into the bottom of the cig lighter socket its only about 5mm long so u can miss it - if i remember mine had a slight plastic coating.
are u getting anything from the electrical connection itself?
:duh: :duh: Fluff, gordy, many thanks, regret cannot see the fusable link, no juice at the socket,
will look for the fuse behind the panel, both the lights for the ashtray and the lighter work, :duh: :duh:
:) :) :) gord, you are correct,behind the panel to the right 0f the accelorater are 18 fuses, a label on the back of the panel identifies them all.
removed the `15a cig`and yes it had blown, replaced and presto a cig lighter that works. now i can recharge my mobile I owe you. :) :) gds
