Carbon Fiber For Rear Skirt
hey does anyone have a link or a picture of a carbon fiber heat sheild for the rear skirt?
its for the rear muff... like the ones you see in EVO7s..
the muffler is protruding then they put like a carbon fiber square to protect the rear skirt so that it will not burn...
you guys have pics?
thanks a lot
keith
if you buy some pre impregnated carbon fibre sheet you will be ableto do one yourself. the sheet is almost sticky as it has a resin that is in the sheet that makes it flexible and strong but under heat hardens. press it on heat it up and your sorted!
