Number Plate Light
Debsy53
hi,
its quite a deal to do the number plate lights.
from what i remember u have to take the liner off the boot lid and then remove some nuts that hold the trim strip around the boot lock on. remove that and then u can access the lenses for the number plate lights.
BUT someone has also said that u can just use a small screwdriver and take out the lens - have a good look first.
Ok firstly the inerior boot lid trim and hinge covers need to be removed.
Next there is 4 nuts (think its 4) that hold the outer number plate cover on (the coloured bit where the lock hole is)
Think the lock barrel has to be removed to as it also holds the cover on (ages since I did one, lol)
The no plate lamps should just flick out once everything is removed
Hope thats some kind of help to you
