Excel Formula Help Please
Fargo
need a formula to do the following.
Have the letters A to P.
Have 12 letters from the above 16.
Need the formula to check the 12 and return the missing letters.
i have lots of these to check, so would like a formula to do it in one hit..
help
You'll have to add a macro.
Open Excel then :
Tools / Macro / Visual Basic Editor
Insert / Module
Click on the (new) Module1
Paste in the following :
Public Function MissingLetters(ByVal strSource As String) As String
    Dim intIdx As Integer
    Dim strResult As String
    Const KEYSTR = "ABCDEFGHIJKLMNOP"
    strSource = UCase(strSource)
    For intIdx = 1 To Len(KEYSTR)
        If InStr(strSource, Mid(KEYSTR, intIdx, 1)) < 1 Then
            strResult = strResult & Mid(KEYSTR, intIdx, 1)
        End If
    Next intIdx
    MissingLetters = strResult
End Function
Save and close the VB editor
You should now have a new user defined function called 'MissingLetters()'
Use it like any other function.
Hope this does what you want.
