Electrical Problem... Help Me...
Hi guys, the night of 31/12/2004 my two low beams died, so i had to go home only with fog lights and hi beam lights.
Now the problem is that the fuse it's ok (I'll check another time... WERE IS THE LOW BEAM FUSE? WHAT NAME DOES IT HAVE?) the bulbs are ok anche the relay it's even ok
:shutit:
Help me please....
i drove 400Km in the dark only with fog lights :ph34r::whistling::driving:
In the engine compartment, left hand side closest the windscreen. Labelled H-LP xxx
As both sides are on seperate fuses, I suspect it is the relay or switch. The relay is in the same compartment (bottom leftmost).
Can you hear it click if someone switches on the lights for you?
