Microsoft Excel Help Required
I'm trying to do a count as below ( actually want to do it on dates but can't get it to work on numbers ) ...... pretty easy to explain
A1 - 5
B1 - 4
B2 - 5
B3 - 6
C1 - in here I want to count the number of entries in B1:B3 that are less than A1 ( answer should be 1 ).
I've tried countif but it won't recognise the A1 cell, will work with a constant though or = to a cell.
Any ideas? It's quite a complex spreadsheet so i can't go setting other cells first :(
OK - hadn't fully understood the problem.
See what you mean about COUNTIF.
=FREQUENCY(B1:B10,A1)
is close except that it includes the case where values are equal - i.e. <=, not just <. You could use the this and reference A2 instead of A1 where A2 = A1-1.
Other option is to add another column that holds 1 if less than, 0 if equal or above and sum the column.
Good luck. Excel is wonderful most of the time and a pain in the a** for the rest.
