Dash Lcd Unit Plug Wiring Altezza Rs200
Does anyone have the actual wiring connections for the dash lcd unit plug connections.
I'm in th process of building a Car CPU that will fit inside the standard CD unit, figured it is a great place to put it as the CD unit don't work.
:blink:
what conections are you after in particular, how do you intend to wire in your carputer, ther are a few of us that have already done installs,, have a look at the link in my siggy below for a start
Thank you for the reply, I'm wanting to connect from carputer to standard (Altezza) flip-up screen, I note in most installs a non standard screen has been used.
I'm considering using a VIA Epia motherboard (www.mini-box.com) with the LVDS option - RGB-01 Module this allows the module to be wired to an RGB screen, hence the need to know the screen pin outs.
DC to DC converter andITPS module (power control ) all from www.mini-box.com
The Sat Nav is still in the car, but does not work in NZ therefore I'm installing a USB GPS receiver onto the carputer.
Operating system will be Fedora core 2 linux, XMMS as music interface and GPSDrive for the GPS system.
OK I may have to change screen, but would like to give it my best before changing.
Cheers
