3s-gt Engine
bigal
search is your friend.
Firstly the altezza is a 3s-GE with dual VVTI
the 3s-gte is the turbo version of the 3sge.
the altezza engine is of all aluminum construction, the 3s-gte is a Iron block aluminum head
would it fit.yes, but will take some custom fabrication, and also you will require the engine loom and ecu..............................obviously had you done a search, all this infomation would have been easy to find, as it has been discussed, only within the past 2 weeks :winky:
having done a search, on a few of your posts, if insurance on an Altezza is gonna be hard to get, how much do you think you will have to pay on a modified IS200, thats had the engine changed to a turbocharged one :duh:
