Annoying Door Rattle
Damer
Drivers door panel has started a really annoying buzzing/rattle especially with bassy music/at speed. Not the speaker as still does it with stereo off. Any ideas for quick fix before I take it back to dealer?
Same rattle with my car, but it occurs not always, more when i go on bumpy road. It looks like some part of panel is loose. The rattle seems to be in the left side of the door (near to the safety belt).
Sorry, no advice from me, but if you know what to do about it, i will also be thankful.
Mine had an irritating driver's door/window rattle when new. The dealer fixed it under warranty by adjusting the door hinges to pull the door tighter into the seal. Said he'd had a couple of cars in with the same problem.
My car (1 year old) is in at the dealer again at the moment to get the door frames re-sprayed under warranty. I noticed a slight "blueing" on the top edge of the frames which looked like corrosion. Again he'd seen a few ISs with the same thing and said it was a clear warranty fix.
