Help With Fuse
nicnac
A friend who has a 2001 IS200 son was doing something with the interior lights(not sure what) and has caused a problem .The interior lights dont work and the central locking doesnt either.The boot wont open either useing key button.
He has checked the fuses in the engine bay and the drivers kick panel.
Is there more fuses somewhere relating to this ?
regards
Nicnac
I would double check the fuses again. Fuses like dome, mpx-b, ecu-b1, door should be double checked.
There are 3 fuse boxes, one in the engine bay and drivers & passengers kick panels.
If all the fuses are ok then the body ECU may be damaged but I'm sure it will just be a fuse - sounds like the passenger fuse box wasn't checked and I think the fuses I listed are located there.
Colin,It turned out to be the DOME fuse 7.5A in the passenger kick panel.Now sorted .....he sends his regards!
nicnac :D
I think i might have the same problem with the fuse. What type of fuse are these the small blade fuse and where can i get a replacement? Thanks
