Check Engine Light Coming On
RS200_Altezza
Hey guys
I have an Altezza RS200 with the 3sge engine and 6 spd tranny.....my check engine light comes on periodically, when it is on the car bogs down badly, sluggish performance, rapid fuel comsumption, rought jerky gear changes and whats not!
I had a diagnosis done and it gave me an O2 sensor reading. My question is...do you guys think it may just be a wire breakage on the sensor? If the sensor was totally bad it would not work at all I thought.
I await your feedback....
  • 14 years later...
i had the same problem and i found the solution...
it was so simple.
i installed a non original ignition coil and that was where the problem began
it took me 3 months to think of it
the diagnostic could not find any problem
so for the 3sge owners
call toyota  say 90919-02236
and then install it
and my lovely altezza is happy again
