2001 Has Dvd Or Cd
asifk
Hi all,
I'm about to buy a 2001 SE, and was wondering if this model has a DVD navigation or CD? Are there any enhanced features on the DVD?
Should I be worried that the thing may not work properly? When I test drove it, I checked it by simply trying to find my place which was 15 miles away (not the best way i know).
Also, does the navigation cover roads all over Europe? In case I take it on a trip on the continent?
thanks very much for the help.
-Asif
depends when in 2001 it was made.
the nav was upgraded to DVD around Sept 2001 I believe - so if its a 51 01, you should be OK.
its easy to tell.
The CD nav had a remote control unit.
The DVD nav has a fixed control unit where an arm rest should be / by the gear shift / handbrake.
The DVD works all over Europe (although I never tested how comprehensive the cover was)
The CD works only in the UK - if you want to use it abroad you have to get a different disk. Lexus have been known to load people disks for holidays in France etc.
Hey thanks for the info. The one I'm seeing is 51 reg, but has a REMOVABLE remote that mounts just ahead of the armrest. does that sound familiar / right? so basically you can use it plugged in as well as like a remote.
was the older one different?
thanks
thanks
that sounds like the remote control on the older versions - so it will be a CD based nav system
Yes defo sounds like the older CD version. If you do want to go abroad ring Lexus GB about 6 weeks in advance and they will oan you a France or whatever disc free of charge, with the exception you have to pay for recorded delivery to send it back. I used it 3 times.
