Oil Pressure & Temperature Gauges..
I have just received my nice new gauges, and want to know if anyone has a recommendation for the best location for the sender units. On the Impreza I fitted the Oil Pressure sender on a T-piece with the original OEM sender, can I do this on the IS?
Again, on the scoob I bought a sump plug which was pre-threaded for the temp sender. Is there a recommended position for it?
Thanks in advance for suggestions/help
Edit: Forgot the obvious, can someone confirm the thread size for the OEM Oil Pressure sender switch, and the thread size of any aperature suitable for the temp sender?
