Sat Nav Information
The details on my Sat Nav Dvd are -
Ver 1st 2002
86271 24121
86271 70v311A
Does any one know which of these are the most relevant.
I have seen Dvd's with the 86271 but with 64XXX numbers instead of 24xxx
and with 60Vxxx instead of the 70Vxxx.
Will these work?
What are the differences?
There are 3 part numbers - 2 printed on the disc and another one printed on the box (this is the number you would normally use to order)
The part number will normally be very close to your original disc. e.g. if you have 86271 24121 then the next one would be 86271 24122.
If the numbers are completly different then it is probably for a different version of nav unit unless Toyota have changed their numbering.
