Map Lights
GALLA_4
Hmm...... I haven't done it but I would assume that you can unclip the covers off?
You are talking about the 2 lights that point to either passenger or drivers side?
I'm sure it must be striaght forward, normally use something flat to gently unclip it.
Sorry I can't be of more help, surprised no one's shared their knowlege yet :)
Push the lense in the middle and gently pull the edges, as its secured by two tabs, one either side (one to the front of the car, one to the rear). By pushing it in the middle it should allow you to ease it off. I think the bulb is a BA9 fiting but it might be a BA7. You can tell by the width of the base, being either 7 or 9mm
