Coilovers
I am considering a set of Tein CS for my car - and have some (embarassingly) basic questions.
1 - how heavy are they? Only place I have seen an indication is on lextasy (you have to add to cart and checkoput). That says 65 lbs - 15lbs per corner, or 7 bags of sugar? Is that weight right?
Seems awful heavy. I know they can't be light as a feather - but that seems a lot. How heavy are the standard components?
2 - Can you see the struts through the wheels?
Sad - I know. :blush:
But the CS are an especially tacky gold colour - and I really wouldn't want them to be visible if I could help it.
3 - How do you adjust the height?
Specifically - can you do it with the car on the road, or does it need to be on a ramp / jacked up?
Once you have finished laughing at my cluelessness - would appreciate your answers :D
you also have to remove the wheel to alter the ride hight.
when I had the Teins on my IS
it was a 20 min job to jack up the car and take the wheel off and adjust the ride hight with the spanners provided.
I couldnt see the teins thru the wheels as the brake discs/drums etc obscured the view.
the ones I had the Tein Flex, were heavy, but didnt feel as heavy as the OEM shocks.
Matt, from what I know (which isnt a lot) you need to drop the wheel completley down, which i suppose you could do on the road with a trolley jack - but me, i'd want it done on a ramp...
thanks guys.
how do you go about the iterative process of getting the right ride height?
I initially did not want coliovers, as I dont need to adjust the ride height - these things will probably be set once and stay there.
but surely it takes a few iterations to get it right?
Down a bit
Down a bit
Down a bit
Ooh no - too hard
Up a bit again
a bit like that?
alex, are the CS the rubber or ball joint tops.
mat,, yes its a process to getthe right height but can be done in about 3 go's
ie do the rears, then measure the distance fromthe bottom of the thread to the lock not you adjust and do the same on the other pair,,
woooo
I like the sound of noiseless....
the pillowball mounts drove me mad!!!
Alex, How hard are they to fit to the GS?
I had sooo much problem getting my old shocks off my IS, I had to jump up and down on the rear hub to get enough clearence to remove the oem strut!!!
my friend who helped was not a happy man by the end of it all hehe
i have removed and installed shocks/springs and coilovers on my car for 4-5 times, without too much trouble.
However, i used a bridge.
Also, the GS and IS suspension setup and shocks/coilovers are very much alike, such that i guess that the installation for both cars is comparable.
i have promised a friend that he will get the first option on my Tein CS.
But ... i also have an used set of Apexi WS coilovers for sale soon ... These will give the same ride as stock, but are not stiffness adjustable.... I will post some pics next week when I am back from my trip.
