IS200 Nav mount still wanted!!!
Hi all
Im still looking for an Is200 Navigation mount, including or minus screen (pref), got my screens in the headrests for the back and my XBOX in, all I need is to fit one in the front and I'd like it to look OEM, if anyone has one or knows where there is a navigator in a scrappers, please let me know
Cheers
Adeyb
  • 1 month later...
Here are the Toyota part numbers for the Nav Casing + Motor - keep in mind that it costs about $700 US dollars.
Top Air Vent Peice - 55662A
Screw Cover for Air Vent Peice - 55544D
Up/Down Button - 84932A
Tilt Button - 84932A
Connecting Wire for Buttons and Tilt Control
to Circuit Board - 82141B
Screen Top Cover - 55443A
Screen Casing - 55479B
Circuit Board Casing/Holder - 86843
Circuit Board/ECM - 55313B
Under Mount peices required for movement - 55683
Right Side Pivoting Mount - 55682
Left Side Pivoting Mount - 55681
Motor - 85435A
Gear - 55678A
  • Topics
  • Our picks
    • All-new Lexus RX: luxury expressed in interior design simplicity
      Lavish details and flourishes are not necessarily the best way to express luxury. A “less is more” approach with design simplicity can be a much more effective way to communicate high quality, as witnessed in the interior of the all-new Lexus RX
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
