Problem...
Just noticed yesterday, whilst driving there seems to be a scraping noise coming from the gear stick and not the gear box. Only happends when changing gears and resting hand on the gear stick and only in 1, 3 and 5 gears! It's seems like it's rubbing on something while resting/pressing down on the gear stick. Never had that problem, always drive like that!
What could be the problem :question:
  • 2 months later...
take it to the dealers. i have the same prblem but in 4th & 6th. somthing to do with the bushes inside. got a new gear stick on order under the warranty.
Sanj mate, is this only since fitting the B&M Short Shifter?
I get extra noise with mine over the standard shifter but not sure if it's the scraping noise you describe?
@ nangley, I assume you haven't got the new stick yet? Let me know if that improves or not!?!?
Looking at C.Shipleys reply, hez saying something different....!?!?
@ aido, the noise was there before the B&M shifter but it has made it more nosier, as described above, after istallation!
