oxygen sensor
yes as far as im aware the lambada(?) sensor will cause the check engine light to come on if its faulty.
also if u have used an engine/carb cleaner type of solvent that has come into contact with the sensor that can damage it as well ( says on can if its safe for use with sensors)
hope this helps - what prob have you got???
robbie
[Edited on 12-2-2002 by fluff34567]
