Slight knocking sound front nearside caliper
daxion
Hi all,
I've just exchanged my CLK230K (had from new, decided time for a change) for an LS400 '93.
Although it's in mint condition there is a slight clunking sound from the nearside front under braking and turning right.
Doesn't do it under hard/gentle left/right turns.
I've inspected the caliper everything looks ok.
Could it be the strut?
Suggestions?
Has anyone changed the stereo, as I want to fit a DVD and TV.
Dave :?:
i had something similar on the IS - it turned out to be the pads just movingever so slightly within the caliper because they are not an exact fit. i just re greased the ends of the pad backing material andi t cured the problem.
BUT also have a look at your anti roll bar mountings and see it they are loose or worn as that can also produce a knock sound.
