  • 5 weeks later...
How do you replace blubs?
I might be able to help on this being a new owner myself this was one of the first things I had to do!!! You'll need to pop off the black plastic panel that goes across the boot lip, there are a couple of studs you'll need to lever out with a flat screwdriver, and then lift the panel up and out. Next, the carpet to the side of the car in the boot needs to be moved to reveal two screws, undo these and then pinch the two plastic pinch fastners in to release the light from it's housing and Voila!!! Simply find the bulb you need to replace I think it's the lowest one, twist and pull!!
Hope this helps
