Tte Coilovers
Niraj
well, my guess for choosing front and rear springs was on a set of reasons.
I called autobase jemca, and got them to check the part numbers, but they couldn't match them with anything.
I tried to call TTE but they were closed.
My reasons and logic for choosing fronts and rears >
The AM27620 springs were visually thicker across the diameter of the spring.
If you could uncoil the entire spring, it would be about 10cm longer.
Although visually you wouldn't be able to see a difference with height (when coiled).
The spring rates are meant to be higher for the front. Thus a thicker longer spring = stronger spring??
The drive is REALLY so good now, that I dont think it can get much better.
Now the springs have been paired correctly, the adjustment remaining on the threads are equal, and the car sits equally lowered. Visually much better also. :)
I'll give TTE a call in the morning but I'd say it's right now :D
  • Replies 80
  • Created
  • Last Reply
Top Posters In This Topic
i agree your more than likely have everything right, i just dont see the logic of doing the complete change, THEN questioning if its right, i hope for you it is
TTE is open today, i was on the phone to them at 14:20
i guess i forgot to mention, i did this on saturday... :blush:
