Copper Grease
d3fy
Hi all,
My car goes next week to it's new owner, I have no issues with selling the car and there is nothing I know about that is a 'issue' except, the damn knocking caused by the pad moving in the shoe (is the right?) When I last had it serviced they copper greased it and it solved it for 3/4 months.
Question, can I copper grease the caliper without taking it to bits to solve the problem?
Probably struggle as you need to put the c.grease on back plate where the piston would push and possible to end part of the pads what look like a T and would slot into the calliper.
Should only be an half hour job though in any case. :)
