Tesco 99ron
Jiberjaber
2008 Abingdon 31/08/05
2030 Andover 26/09/05
2031 Ashford Crooksfoot 11/08/05
2147 Ashford Middlesex 18/08/05
2039 Ashford Park Farm 21/07/05
2041 Aylesbury 2
2055 Baldock 29/09/05
2065 Bar Hill 07/09/05
2072 Barking 13/09/05
2078 Barkingside 10/10/05
2073 Basildon 1 25/10/05
2082 Basildon 2 12/10/05
2080 Basingstoke 03/10/05
2105 Bedford 2 01/08/05
2101 Bishop Stortford 05/09/05
2117 Blandford Forum 28/07/05
2102 Bognor 14/09/05
2126 Borehamwood 20/09/05
2115 Bracknell North 16/08/05
2131 Brent Cross
2122 Brent Park 07/09/05
2141 Brislington 19/07/05
2200 Broadstairs 08/08/05
2152 Bromley By Bow 27/09/05
2160 Brooklands 12/10/05
2163 Burgess Hill 24/10/05
2156 Burlesdon Towers 24/10/05
2166 Bury St Edmunds 20/10/05
2330 Chelmsford 28/09/05
2266 Chichester 13/09/05
2310 Colchester 06/10/05
2296 Colney Hatch 22/08/05
2436 Dereham 27/09/05
2413 Didcot 17/08/05
2422 Dover 10/08/05
2425 Dunstable 01/09/05
2450 Eastbourne 13/10/05
2445 Elmers End 06/10/05
2470 Ely 19/10/05
2532 Feltham 06/09/05
2538 Feltham Dukes Green 11/10/05
2547 Flitwick 02/08/05
2569 Goodmayes 12/09/05
3490 Great Yarmouth 08/09/05
2634 Harlow CL 31/10/05
2639 Harlow EW 27/09/05
2691 Hastings 19/09/05
2654 Hatfield 28/09/05
2651 Havant Langstone 12/09/05
2642 Hayes Bull Bridge 23/08/05
2663 Hemel Hempstead 27/07/05
2675 Horsham 15/09/05
2748 Ipswich 01/09/05
2767 Kettering 31/08/05
3333 Lea Valley 23/08/05
2812 Leatherhead 01/08/05
2821 Lewisham 05/10/05
2833 Littlehampton 01/09/05
2848 Lowestoft 11/10/05
2857 Lunsford Park 21/09/05
2860 Maidstone 04/10/05
2872 Maldon 29/09/05
2877 Martlesham 29/09/05
2889 Milton 18/10/05
2898 Milton Keynes Bletchley 03/08/05
2896 Milton Keynes Wolverton 04/08/05
2885 MK Kingston 30/08/05
2934 New Malden 26/10/05
2919 Newbury 18/08/05
2941 Newmarket 20/10/05
2952 Northampton 17/10/05
2128 Osterley 24/08/05
2994 Oxford 15/08/05
3009 Peterborough 19/10/05
3068 Pitsea 26/09/05
3032 Ponders End 24/08/05
3040 Poole 3 Fleets Corner 20/07/05
3055 Portsmouth 25/10/05
3050 Potters Bar 25/08/05
3066 Purley 07/09/05
3086 Rainham 14/09/05
3095 Reading 15/08/05
3107 Romford 20/09/05
3120 Romford Gallows 21/09/05
3130 Saffron Waldon 17/10/05
3179 Sheerness 06/09/05
3178 Shoreham 19/09/05
3180 Sidcup 08/09/05
3177 Southend 27/10/05
3189 Southwark 04/10/05
3145 St Neots 10/10/05
3240 Stowmarket 28/09/05
3234 Sudbury 05/10/05
3220 Sunbury 17/08/05
3205 Surrey Quays 03/10/05
3235 Sutton Cheam Park Farm 31/10/05
3324 Twickenham 25/08/05
3372 Watford 02/08/05
3436 West Durrington 27/10/05
3377 Weston Flavell 31/08/05
3401 Whitstable 15/09/05
3470 Yeading 22/08/05
to follow soon
2296 Colney Hatch 01/11/05
3050 Potters Bar 02/11/05
2651 Havant Langstone 03/11/05
2569 Goodmayes 03/11/05
2560 Gatwick 07/11/05
2266 Chichester 07/11/05
2072 Barking 08/11/05
2102 Bognor 08/11/05
3086 Rainham 09/11/05
2675 Horsham 09/11/05
3401 Whitstable 10/11/05
3178 Shoreham 10/11/05
3324 Twickenham 14/11/05
2691 Hastings 14/11/05
2425 Dunstable 14/11/05
3107 Romford 15/11/05
2126 Borehamwood 15/11/05
3120 Romford Gallows 16/11/05
2857 Lunsford Park 16/11/05
Shamlessly stolen from another forum but thought it might be of use :)
So anyone running on it have anything to report, I might try a few tanks or so when I get through my current Optimax testing :)
Good list Jase, but some of the "to follow soon" ones are actually listed in the main ?
Yup I noticed that too... it is a direct copy from the source post so I CBA to edit the list, didnt want to make it look like some paces had the 99 stuff when they might not have :)
have used a couple of tanks, seems to be slightly more responsive, but it has a tendancy to disapeer :excl:
odly it wasnt the foot on the floor to much, just more along the lines of it didnt appear to be as econmic (not sure that words fitting tho) but worth experimenting with an cheaper than optimax! :)
Cheshunt and Stevenage are missed off the list.
I've been using it for about 2 months now, can't sat any better than Optimax but the car runs good on it.
It's about 1 or 2p/l cheaper than Optimax round here and MPG is about the same
tesco 99 ron was at the pumps in prestwich, manchester for quite a few monthsfor the same price as normal unleaded but disappeared just before i moved for some reason. here in ashby there is normal and super 97 ron, wow! :blink:
Was using it during the summer for a few tank fulls.
MPG was ok but nothing out of the special.
However after an initial fill up it does make everything smoother. Especially take off - less clutch judder.
The effect seems to wear off as the ecu works out the extra RON.
5TH Gear on monday night (14/11) are supposed to do an article on premuim fuels which should be interesting.
You're not kidding. I'm just trying a tank and from the fuel gauge so far it looks like I'm getting about 14 mpg instead of 28 :o :crying:
(And yes I have reset the ECU.)
did u do the long term memory reset of the ecu
mat showed this to me
the car will then drive like $hit for a few miles until it relearns everything
think it is a case of disconnect bat6tery for half an hour
oddly enough mine worked out at 14mpg aswell, back on cheap at the mo as could only find a asda when i needed to fill up :unsure:
I did reset the ECU by pulling the EFI & ETCS fuses but not straight away. I guess it hadn't had long enough to learn about the new fuel with my driving etc. I topped up with some 95 ron again today so now it's somewhere in between with the 99 ron thats left and I've reset it again. Hopefully it won't be quite so bad now. It was an impulse thing to try one tank for an experiment but now I see it would have to be a bit more of a sustained experiment. Calculated mpg as 17mpg but it did go like it had a rocket tied to it. :)
I'm looking forward to getting a prolex induction kit so I can get it a bit more responsive without the fuel cost issue.
