Hi all,
Due to the high petrol prices over the last few months I have been running my car on the cheapo 95 octane grade. I had been noticing that my car was running very rough and was contemplating the engine mounts, spark leads or even the 6 month old plugs, since it is designed to run on 95 octane.
As an experiment I ran the tank nearly dry and put in £20 of 97 grade and it is purring away again. Glad I didn't strip it down!
I don't remember the car behaving like that when I first got it 6 months ago so is it my memory or have I just gotten used to the smoothness and can now detect slight changes when running on low grade?
Anyone having similar experiences?
Cheers,
Leadfoot
Hi all,
Cheers,
Leadfoot
don't think its down to the slight drop in octane fuel is hydroscopic it absorbs water and you will always find a few garages that are reknown for having water in their tanks. there used to be a few you had to avoid like the plague around here if you always fill up at the same garage try changing where you get it from
