Heated Rear Window (pants)
crewe
Don't be lazy scrape the outside clear then it will de-mist in no time.
I always pour over hot TAP water ONLY if iced up. after starting and getting de-mister etc all going. This also has the advantage of warming up the glass and reducing demist efforts.
Off and going in no time, I dont like de-icer sprays and they take too long anyway.
HOT water may crack the screen, always best to use de-icer.........i've heard that you shouldn't spray de-icer on the rubber around the screen, it can damage it?
