Tezza Auto Gearbox Fluid Change.........
mus26c
I am planning to change my gearbox fluid, I checked it this morning and it was brownish. Whats the best fluid available in the market today??
Is it worth repalcing the differential fluid same time?
I found few links to assist me with my DIY, but they only apply for IS300
http://my.is/forums/showthread.php?p=3502990#post3502990
http://my.is/forums/showthread.php?t=254631
Thanks in advance :)
Thanks for the reply mark, The redline fluid is it for both auto gearbox and defferential? what about the quantities how much do I need??
thanks in advance  :)
You will need the corret fluid for each appliaction. We have both in stock. We will look the quantities at the time of the order (don't have time at the mo), alternatively it is probably in the owners hand book :)
Same here, i tried to get hold of the TYPE T-IV spec from usual motor shops, had to get it from toyota in the end.
Capacity is 2.4 litres, but you never quite use that much as not all of it comes out, I think I used 1.8litres...
