Pollen Filter
NetOne
Lexus IS250 has a breakthrough system to remove pollen from the cabin.
The breakthrough Lexus pollen removal mode is designed to optimise occupant comfort by quickly removing pollen present inside the car from around the upper bodies of the driver and front passenger.
This feature is part of the raft of technology introduced in Lexus’ newest and what is predicted to become its most successful model yet.
The pollen removal function is an additional feature to IS250’s clean air (pollen) filter, introduced in Lexus in 1994 and standard across every model.
It builds on the hallmark Lexus cabin comfort technologies of a smog ventilation sensor and an easy-to-change pollen filter in the air conditioning system.
Does IS200 have pollen filter that can remove pollen from the cabin as the IS250 ?
the IS250 pollen filter is different from the IS200. The IS 200 is just your basic A/C filter behind the glove box, whereas the IS250 seems to be equiped with a Pollen filter /deioninser extractor (with a special pollen extract button as well) + A/C filter
