Fuse Box Location
prento
Hi Guys,
Can someone tell me just where I can locate the fuse box that houses the fuses for the rear park lights :question: :duh: I have searched this car hi and low to no avail.
I have an 99 Altezza and have so far located 3 fuse boxes (2 under the hood and one on the passenger side below the glove compartment almost next to the floor mat).
Hi Guys,
Should find it in the footwell fusebox
  • 15 years later...
19 hours ago, Gofaone said:
Which fuse to check if the hooter is not working
On the Lexus IS200 / IS300 there is a 10A fuse labelled HORN which is in the engine bay fuse box. The horn itself is activated via a relay so that would need checking too if the horn isn't working.
I imagine the AS200 and RS200 Altezza are the same.
