220bhp Possible?
Pip
i think its gettin there.. but not quite.
I think the kazama and CAI will get u around 5-7 hp. The SC will get u 210 automatically.
If u decat .. that should put you over 220. Decat is just removing the precats that are existing on your car. Its not a "mod" per se.
I think if u put on the prolex header as well... u go all the way up to 240+
If i de-cat it will i have to go through the process of putting it back on for the MOT etc?
I have also heard that de-catting leads to a lot of issues with the lexus, ecu etc??
NO and NO :D
By de-cat i take it you mean just the pre-cats..
If you de-cat the car, as in remove the main cat also. It will need to be put back on for mot time. You'll also get the CEL light come on now and again.
But just the precats removed you will be fine. You'll just need to make sure the exhaust temp is up for mot time. So just drive the car around abit before the mot.
