Trd Radiator Cap
Robin H
Been looking at TRD parts on ebay and a lot of the items tell you what they will and will not fit
it list that it will not fit the : MR2 SW20 with 3S-GTE or 3S-GE
so does this mean that this will not fit my altezza
Your RS200 Tezza has the 3S-GE engine.........so no
Fits almost all late models (1993 on) Toyota and Lexus models vehicles and some other makes and models.
not very help full
Will not fit the following models / engines:
* Corolla AE92 GTS with 4A-GZE
* Corolla AE92 with 4A-F, 4A-FE, 4A-GE
* Corolla AE86 with 4A-C
* Corolla AE86 GTS with 4A-GEC
* Supra MA61 with 5M-GE
* Supra GA70 with 1G-GTE, 1G-GE or 1G-FE
* MR2 SW20 with 3S-GTE or 3S-GE
* MR2 SW21 with 5S-FE
* MR2 AW11 with 4A-GZE or 4A-GE or 4A-GELC
* Starlet EP71 with 2E-TE or 2E-E
* 90-95 4Runner with 3VZ-E
* 88-95 4Runner/Truck 4Cyl and 3.0 V6
* 97-01 Camry/Solara V6
* 87-89 Celica with 3S-GTE
* 90-97 Land Cruiser with 1FZFE
isnt it just a normal rad cap with a trd sticker?
I thought the uprated rad caps help have a quicker boiling point for the water coolant inside the rad, making the car reach normal operating temp. quicker?
nope your confuseing that with the Thermostats Ahmet,
Matt, I'm sure I read that somewhere before !?
the thermostats open sooner to allow the engine to run hotter sooner(get upto temp), then the uprated rad caps allow the boiling point to be raised before pressure is released, thats why it is wise to ensure you have a good functioning cooling system before fitting the uprated rad caps
going a bit :offtopic: but staying with eBay and trd parts (as being relativly new to jap tuning) is £20 cheap/expensive for an TRD oil filter
is there anywhere in the uk where I can by trd, tte parts from
like: rad cap, oil cap, fuel cap, oil filters, stickers ect, just little touches
as it can be quite hard to distinguished between real and fakes
I might sound stupid but what is the purpose of this cap then . does it give better perforance etc. :unsure:
I think the Q has already been answered:
The higher pressure allows the thermostat to open earlier as the optimum operating temperature is achieved sooner. Therefore greater efficiency and improved performance.
The downside is, that with a poorly maintained cooling system will be more prone to leaking.
to be honest, i highly dount the stuff on eBay is real trd
if you want real TRD stuff, the TRDUSA stuff can be got from Fensport
engine stuff as i have alreadu pointed out i can get.
just a point though, TRD USA is not part of Toyota its a franchise, and so the "bling" stuff is normally made by TRD USA, the real tuning stuff, cams, pistons etc is made by TRD Japan, which is the tuning side of TOYOTA
