Lexus Error Codes
I have a full list of error codes for most of the lexus models however i have just tried to cut and paste them so i could post them and it won't let me.
If anyone knows how to get around a cut and paste block tyhen let me know otherwise if you post a code in this topic then i can look it up for you
What format is your list in that it prohibits copy/paste?
L.
L.
well lets say its not in word :shifty:
What's it in then? If it's excel you can cut and paste into word. It will have boxes round it. Then Table / convert / convert table to etxt. Then you can cut and paste to here. If it's something else give us a clue and we will fix it. PDF has a cut and paste facility but you have to get it from the toolbar .... hover ... for select I think it is.
I have the same problem when trying to copy info from AutoData but thats only because it may be illegal to print some of the data, I don't know.
nah they are just being annoying but funny you should say about that :whistling:
Acrobat (professional) has an option to prohibit copy/paste from a PDF document when it's created, but there are ways to circumvent that if you have the right utilities... hence my original question.
L.
L.
ah what utilities
EOBD codes
All EOBD codes starting with P zero have standard meanings irrespective of vehicle make or model.
For EOBD codes, other than those starting P zero, refer to model specific chapters.
The following list covers all P0 codes allocated at the time of publication.
Trouble
Fault location Probable cause
code
P0000 No fault found -
P0001 Fuel volume regulator control - circuit open Wiring, regulator control solenoid
P0002 Wiring, regulator control solenoid
range/performance
P0003 Fuel volume regulator control - circuit low Wiring short to earth, regulator control solenoid
Wiring open circuit/short to positive, regulator
P0004 Fuel volume regulator control - circuit high
control solenoid
P0005 Fuel shut-off valve - circuit open Wiring open circuit, fuel shut-off valve
P0006 Fuel shut-off valve - circuit low Wiring short to earth, fuel shut-off valve
P0007 Fuel shut-off valve - circuit high Wiring short to positive, fuel shut-off valve
Engine position system, bank 1 - engine
P0008 Mechanical fault
performance
Engine position system, bank 2 - engine
P0009 Mechanical fault
performance
Camshaft position (CMP) actuator,
P0010 Wiring, CMP actuator, ECM
intake/left/front, bank 1 - circuit malfunction
Camshaft position (CMP), intake/left/front, bank 1 Valve timing, engine mechanical fault, CMP
P0011
- timing over-advanced/system performance actuator
P0012
- timing over-retarded actuator
P0013 Wiring, CMP actuator, ECM
P0011
P0012
P0014 exhaust/right/rear, bank 1 - timing over-
actuator
Camshaft position (CMP) actuator, Valve timing, engine mechanical fault, CMP
P0015
exhaust/right/rear, bank 1 - timing over-retarded actuator
Crankshaft position/camshaft position, bank 1 Wiring, CKP sensor, CMP sensor, mechanical
P0016
sensor A - correlation fault
P0017
sensor B - correlation fault
Crankshaft position/camshaft position, bank 2 Wiring, CKP sensor, CMP sensor, mechanical
P0018
P0019
P0020 Wiring, CMP actuator, ECM
intake/left/front, bank 2 - circuit malfunction
Camshaft position (CMP), intake/left/front, bank 2 Valve timing, engine mechanical fault, CMP
P0021
P0022
P0023 Wiring, CMP actuator, ECM
exhaust/right/rear, bank 2 - circuit malfunction
Camshaft position (CMP), exhaust/right/rear,
P0024 bank 2 - timing over-advanced/system
actuator
performance
P0025
bank 2 - timing over-retarded actuator
Intake valve control solenoid circuit, bank 1 -
P0026 Wiring, intake valve control solenoid
range/performance
Exhaust valve control solenoid circuit, bank 1 -
P0027 Wiring, exhaust valve control solenoid
range/performance
Intake valve control solenoid circuit, bank 2 -
P0028 Wiring, intake valve control solenoid
range/performance
Exhaust valve control solenoid circuit, bank 2 -
P0029 Wiring, exhaust valve control solenoid
range/performance
Heated oxygen sensor (HO2S) 1, bank 1, heater
P0030 Wiring, HO2S, ECM
control - circuit malfunction
P0031 Wiring short to earth, HO2S, ECM
P0032 Wiring short to positive, HO2S, ECM
Turbocharger (TC) wastegate regulating valve -
P0033 Wiring, TC wastegate regulating valve, ECM
circuit malfunction
Turbocharger (TC) wastegate regulating valve - Wiring short to earth, TC wastegate regulating
P0034
circuit low valve, ECM
Turbocharger (TC) wastegate regulating valve - Wiring short to positive, TC wastegate
P0035
circuit high regulating valve, ECM
Heated oxygen sensor (HO2S) 2, bank 1, heater
P0036 Wiring, HO2S, ECM
P0037 Wiring short to earth, HO2S, ECM
P0038 Wiring short to positive, HO2S, ECM
Turbo/super charger bypass valve, control circuit -
P0039 Wiring, bypass valve
range/performance
Oxygen sensor signals swapped, bank 1 sensor
P0040 Wiring
1/bank 2 sensor 1
P0041 Wiring Oxygen sensor signals swapped, bank 1 sensor
P0041 Wiring
2/bank 2 sensor 2
Heated oxygen sensor (HO2S) 3, bank 1, heater
P0042 Wiring, HO2S, ECM
P0043 Wiring short to earth, HO2S, ECM
P0044 Wiring short to positive, HO2S, ECM
Turbo/super charger boost control solenoid -
P0045 Wiring, boost control solenoid
circuit open
Turbo/super charger boost control solenoid - Wiring, boost control solenoid, mechanical
P0046
circuit range/performance fault
P0047 Wiring short to earth, boost control solenoid
circuit low
P0048 Wiring short to positive, boost control solenoid
circuit high
P0049 Turbo/super charger turbine - over-speed Mechanical fault
Heated oxygen sensor (HO2S) 1, bank 2, heater
P0050 Wiring, HO2S, ECM
P0051 Wiring short to earth, HO2S, ECM
P0052 Wiring short to positive, HO2S, ECM
Heated oxygen sensor (HO2S), bank 1, sensor 1
P0053 Wiring, HO2S
- heater resistance
Heated oxygen sensor (HO2S), bank 1, sensor 2
P0054 Wiring, HO2S
- heater resistance
Heated oxygen sensor (HO2S), bank 1, sensor 3
P0055 Wiring, HO2S
- heater resistance
Heated oxygen sensor (HO2S) 2, bank 2, heater
P0056 Wiring, HO2S, ECM
P0057 Wiring short to earth, HO2S, ECM
P0058 Wiring short to positive, HO2S, ECM
Heated oxygen sensor (HO2S), bank 2, sensor 1
P0059 Wiring, HO2S
- heater resistance
Heated oxygen sensor (HO2S), bank 2, sensor 2
P0060 Wiring, HO2S
- heater resistance
Heated oxygen sensor (HO2S), bank 2, sensor 3
P0061 Wiring, HO2S
- heater resistance
Heated oxygen sensor (HO2S) 3, bank 2, heater
P0062 Wiring, HO2S, ECM
P0063 Wiring short to earth, HO2S, ECM
P0064 Wiring short to positive, HO2S, ECM
P0065 Air assisted injector - range/performance problem Air assisted injector
Air assisted injector - circuit malfunction/circuit Wiring short to earth, air assisted injector,
P0066
low ECM
Wiring short to positive, air assisted injector,
P0067 Air assisted injector - circuit high
ECM
Manifold absolute pressure (MAP) sensor/mass Wiring, MAP sensor, MAF sensor, mechanical
P0068
air flow (MAF) sensor/throttle position correlation fault
P0069 sensor/barometric pressure (BARO) sensor MAP sensor, mechanical fault
correlation
Outside air temperature sensor - circuit
P0070 Wiring, outside air temperature sensor, ECM
malfunction
P0071 Outside air temperature sensor
Wiring short to earth, outside air temperature
P0072 Outside air temperature sensor - low input
sensor, ECM
Wiring short to positive, outside air
P0073 Outside air temperature sensor - high input
Outside air temperature sensor - circuit Wiring, poor connection, outside air temperature sensor, ECM
P0074
intermittent temperature sensor, ECM
Intake valve control solenoid, bank 1 - circuit
P0075 Wiring, intake valve control solenoid, ECM
malfunction
Wiring short to earth, intake valve control
P0076 Intake valve control solenoid, bank 1 - circuit low
solenoid, ECM
Wiring short to positive, intake valve control
P0077 Intake valve control solenoid, bank 1 - circuit high
solenoid, ECM
Exhaust valve control solenoid, bank 1 - circuit
P0078 Wiring, exhaust valve control solenoid, ECM
malfunction
Exhaust valve control solenoid, bank 1 - circuit Wiring short to earth, exhaust valve control
P0079
low solenoid, ECM
Exhaust valve control solenoid, bank 1 - circuit Wiring short to positive, exhaust valve control
P0080
high solenoid, ECM
Intake valve control solenoid, bank 2 - circuit
P0081 Wiring, intake valve control solenoid, ECM
malfunction
P0082 Intake valve control solenoid, bank 2 - circuit low
solenoid, ECM
P0083 Intake valve control solenoid, bank 2 - circuit high
solenoid, ECM
Exhaust valve control solenoid, bank 2 - circuit
P0084 Wiring, exhaust valve control solenoid, ECM
malfunction
Exhaust valve control solenoid, bank 2 - circuit Wiring short to earth, exhaust valve control
P0085
low solenoid, ECM
Exhaust valve control solenoid, bank 2 - circuit Wiring short to positive, exhaust valve control
P0086
high solenoid, ECM
Fuel pump, fuel pressure regulator, fuel supply
P0087 Fuel rail/system pressure too low
pipe blockage, mechanical fault
Fuel pump, fuel pressure regulator, fuel return
P0088 Fuel rail/system pressure too high
P0089 Fuel pressure regulator - performance problem Fuel pressure regulator, mechanical fault
Wiring open circuit, fuel metering solenoid,
P0090 Fuel metering solenoid - open circuit
ECM
Wiring short to earth, fuel metering solenoid,
P0091 Fuel metering solenoid - short to earth
ECM
Wiring short to positive, fuel metering solenoid,
P0092 Fuel metering solenoid - short to positive
ECM
P0093 Fuel system leak - large leak detected Wiring, fuel pressure sensor, mechanical fault
P0094 Fuel system leak - small leak detected Wiring, fuel pressure sensor, mechanical fault
Intake air temperature (IAT) sensor 2 - circuit
P0095 Wiring, poor connection, IAT sensor, ECM
malfunction
P0096 Wiring, poor connection, IAT sensor, ECM
range/performance
Intake air temperature (IAT) sensor 2 - circuit low
P0097 Wiring short to earth, IAT sensor, ECM
input
Intake air temperature (IAT) sensor 2 - circuit high
P0098 Wiring short to positive, IAT sensor, ECM
input
P0099 Wiring, poor connection, IAT sensor, ECM
intermittent/erratic
Mass air flow (MAF) sensor/volume air flow (VAF)
P0100 Wiring, MAF/VAF sensor, ECM
sensor - circuit malfunction
P0101 Intake leak/blockage, MAF/VAF sensor
sensor - range/performance problem
P0102 Wiring short to earth, MAF/VAF sensor, ECM
sensor - low input
Mass air flow (MAF) sensor/volume air flow (VAF) Wiring short to positive, MAF/VAF sensor,
P0103
sensor - high input ECM
Mass air flow (MAF) sensor/volume air flow (VAF) Wiring, poor connection, MAF/VAF sensor,
P0104
sensor - circuit intermittent ECM
P0105 sensor/barometric pressure (BARO) sensor - Wiring, MAP sensor, BARO sensor, ECM
circuit malfunction
Intake/exhaust leak, wiring, MAP sensor,
circuit malfunction
P0106 sensor/barometric pressure (BARO) sensor -
BARO sensor
Wiring short to earth, MAP sensor, BARO
P0107 sensor/barometric pressure (BARO) sensor - low
sensor, ECM
input
Wiring short to positive, MAP sensor, BARO
P0108 sensor/barometric pressure (BARO) sensor - high
sensor, ECM
input
Wiring, poor connection, MAP sensor, BARO
P0109 sensor/barometric pressure (BARO) sensor -
sensor, ECM
Intake air temperature (IAT) sensor - circuit
P0110 Wiring, IAT sensor, ECM
malfunction
P0111 IAT sensor
P0112 Intake air temperature (IAT) sensor - low input Wiring short to earth, IAT sensor, ECM
Wiring open circuit/short to positive, earth wire
P0113 Intake air temperature (IAT) sensor - high input
defective, IAT sensor, ECM
P0114 Wiring, poor connection, IAT sensor, ECM
intermittent
Engine coolant temperature (ECT) sensor - circuit
P0115 Wiring, ECT sensor, ECM
malfunction
Engine coolant temperature (ECT) sensor - Coolant thermostat, poor connection, wiring,
P0116
range/performance problem ECT sensor
Engine coolant temperature (ECT) sensor - low Coolant thermostat, wiring short to earth, ECT
P0117
input sensor
Engine coolant temperature (ECT) sensor - high Coolant thermostat, wiring open circuit/short to
P0118
input positive, earth wire defective, ECT sensor Engine coolant temperature (ECT) sensor - circuit
P0119 Wiring, poor connection, ECT sensor, ECM
intermittent
Throttle position (TP) sensor A/accelerator pedal
P0120 Wiring, TP/APP sensor, ECM
position (APP) sensor A - circuit malfunction
Throttle position (TP) switch A/accelerator pedal
P0120 Wiring, TP/APP switch, ECM
position (APP) switch A - circuit malfunction
P0121 position (APP) sensor A - range/performance Accelerator cable adjustment, TP/APP sensor
problem
P0121 position (APP) switch A - range/performance Accelerator cable adjustment, TP/APP switch
problem
P0122 Wiring short to earth, TP/APP sensor, ECM
position (APP) sensor A - low input
P0122 Wiring short to earth, TP/APP switch, ECM
position (APP) switch A - low input
P0123 Wiring short to positive, TP/APP sensor, ECM
position (APP) sensor A - high input
P0123 Wiring short to positive, TP/APP switch, ECM
position (APP) switch A - high input
P0124 Wiring, poor connection, TP/APP sensor, ECM
position (APP) sensor A - circuit intermittent
P0124 Wiring, poor connection, TP/APP switch, ECM
position (APP) switch A - circuit intermittent
Insufficient coolant temperature for closed loop Wiring, cooling system, coolant thermostat,
P0125
fuel control ECT sensor
Insufficient coolant temperature for stable Wiring, cooling system, coolant thermostat,
P0126
operation ECT sensor
Wiring short to earth, IAT sensor 2,
P0127 Intake air temperature too high
mechanical fault, ECM
Coolant thermostat - coolant temperature below
P0128 Mechanical fault
thermostat regulating temperature
P0129 Barometric pressure too low Wiring, BARO sensor, mechanical fault
Heated oxygen sensor (HO2S) 1, bank 1 - circuit Heating inoperative, poor connection, wiring,
P0130
malfunction HO2S
Oxygen sensor (O2S) 1, bank 1 - circuit
P0130 Wiring, O2S, ECM
malfunction
Heated oxygen sensor (HO2S) 1, bank 1 - low Exhaust leak, wiring short to earth, HO2S,
P0131
voltage ECM
P0131 Oxygen sensor (O2S) 1, bank 1 - low voltage Exhaust leak, wiring short to earth, O2S, ECM
Heated oxygen sensor (HO2S) 1, bank 1 - high
P0132 Wiring short to positive, HO2S, ECM
voltage
P0132 Oxygen sensor (O2S) 1, bank 1 - high voltage Wiring short to positive, O2S, ECM
Heated oxygen sensor (HO2S) 1, bank 1 - slow
P0133 Heating inoperative, wiring, HO2S
response
P0133 Oxygen sensor (O2S) 1, bank 1 - slow response Wiring, O2S
Heated oxygen sensor (HO2S) 1, bank 1 - no
P0134 Wiring open circuit, heating inoperative, HO2S
activity detected
Oxygen sensor (O2S) 1, bank 1 - no activity
P0134 Wiring, O2S
detected
P0135 Fuse, wiring, HO2S, ECM
Heated oxygen sensor (HO2S) 2, bank 1 - circuit
P0136 Heating inoperative, wiring, HO2S, ECM
malfunction
Oxygen sensor (O2S) 2, bank 1 - circuit
P0136 Wiring, O2S, ECM
malfunction
Heated oxygen sensor (HO2S) 2, bank 1 - low Exhaust leak, wiring short to earth, HO2S,
P0137
voltage ECM
P0137 Oxygen sensor (O2S) 2, bank 1 - low voltage Exhaust leak, wiring short to earth, O2S, ECM
Heated oxygen sensor (HO2S) 2, bank 1 - high
P0138 Wiring short to positive, HO2S, ECM
voltage
P0138 Oxygen sensor (O2S) 2, bank 1 - high voltage Wiring short to positive, O2S, ECM
Heated oxygen sensor (HO2S) 2, bank 1 - slow
P0139 Heating inoperative, wiring, HO2S
P0139 Oxygen sensor (O2S) 2, bank 1 - slow response Wiring, O2S
Heated oxygen sensor (HO2S) 2, bank 1 - no
P0140 Wiring, heating inoperative, HO2S, ECM
activity detected
Oxygen sensor (O2S) 2, bank 1 - no activity
P0140 Wiring, O2S, ECM
detected
P0141 Wiring, HO2S, ECM
Heated oxygen sensor (HO2S) 3, bank 1 - circuit
P0142 Wiring, HO2S, ECM
malfunction
Heated oxygen sensor (HO2S) 3, bank 1 - low Exhaust leak, wiring short to earth, HO2S,
P0143
voltage ECM
P0143 Oxygen sensor (O2S) 3, bank 1 - low voltage Exhaust leak, wiring short to earth, O2S, ECM
Heated oxygen sensor (HO2S) 3, bank 1 - high
P0144 Wiring short to positive, HO2S, ECM
voltage
P0144 Oxygen sensor (O2S) 3, bank 1 - high voltage Wiring short to positive, O2S, ECM
Heated oxygen sensor (HO2S) 3, bank 1 - slow
P0145 Heating inoperative, wiring, HO2S
response
P0145 Oxygen sensor (O2S) 3, bank 1 - slow response Wiring, O2S
Heated oxygen sensor (HO2S) 3, bank 1 - no
P0146 Wiring, HO2S, ECM
activity detected
Oxygen sensor (O2S) 3, bank 1 - no activity
P0146 Wiring, O2S, ECM
detected
P0147 Wiring, HO2S, ECM
P0148 Fuel delivery error Fuel pump/fuel injection pump
P0149 Fuel timing error Fuel pump/fuel injection pump
Heated oxygen sensor (HO2S) 1, bank 2 - circuit
P0150 Wiring, HO2S, ECM
malfunction
Oxygen sensor (O2S) 1, bank 2 - circuit
P0150 Wiring, O2S, ECM
malfunction
Heated oxygen sensor (HO2S) 1, bank 2 - low Exhaust leak, wiring short to earth, HO2S,
P0151
Heated oxygen sensor (HO2S) 1, bank 2 - high
P0152 Wiring short to positive, HO2S, ECM
voltage
P0152 Oxygen sensor (O2S) 1, bank 2 - high voltage Wiring short to positive, O2S, ECM
Heated oxygen sensor (HO2S) 1, bank 2 - slow
P0153 Heating inoperative, wiring, HO2S
response
P0153 Oxygen sensor (O2S) 1, bank 2 - slow response Wiring, O2S
Heated oxygen sensor (HO2S) 1, bank 2 - no
P0154 Wiring, HO2S, ECM
activity detected
Oxygen sensor (O2S) 1, bank 2 - no activity
P0154 Wiring, O2S, ECM
detected
P0155 Wiring, HO2S, ECM
Heated oxygen sensor (HO2S) 2, bank 2 - circuit
P0156 Heating inoperative, wiring, HO2S, ECM
malfunction
Oxygen sensor (O2S) 2, bank 2 - circuit
P0156 Wiring, O2S, ECM
malfunction
Heated oxygen sensor (HO2S) 2, bank 2 - low Exhaust leak, wiring short to earth, HO2S,
P0157
voltage ECM
P0157 Oxygen sensor (O2S) 2, bank 2 - low voltage Exhaust leak, wiring short to earth, O2S, ECM
Heated oxygen sensor (HO2S) 2, bank 2 - high
P0158 Wiring short to positive, HO2S, ECM
voltage
P0158 Oxygen sensor (O2S) 2, bank 2 - high voltage Wiring short to positive, O2S, ECM
Heated oxygen sensor (HO2S) 2, bank 2 - slow
P0159 Heating inoperative, wiring, HO2S
response
P0159 Oxygen sensor (O2S) 2, bank 2 - slow response Wiring, O2S
Heated oxygen sensor (HO2S) 2, bank 2 - no
P0160 Wiring, HO2S, ECM
activity detected
Oxygen sensor (O2S) 2, bank 2 - no activity
P0160 Wiring, O2S, ECM
detected
P0161 Wiring, HO2S, ECM
malfunction
Oxygen sensor (O2S) 3, bank 2 - circuit
P0162 Wiring, O2S, ECM
malfunction
Heated oxygen sensor (HO2S) 3, bank 2 - low Exhaust leak, wiring short to earth, HO2S,
P0163
voltage ECM
P0163 Oxygen sensor (O2S) 3, bank 2 - low voltage Exhaust leak, wiring short to earth, O2S, ECM
Heated oxygen sensor (HO2S) 3, bank 2 - high
P0164 Wiring short to positive, HO2S, ECM
voltage
P0164 Oxygen sensor (O2S) 3, bank 2 - high voltage Wiring short to positive, O2S, ECM
Heated oxygen sensor (HO2S) 3, bank 2 - slow
P0165 Heating inoperative, wiring, HO2S
response
P0165 Oxygen sensor (O2S) 3, bank 2 - slow response Wiring, O2S
Heated oxygen sensor (HO2S) 3, bank 2 - no
P0166 Wiring, HO2S, ECM
activity detected
Oxygen sensor (O2S) 3, bank 2 - no activity
P0166 Wiring, O2S, ECM
detected
P0167 Wiring, HO2S, ECM
Wiring, fuel temperature sensor, mechanical
P0168 Fuel temperature too high
fault
Wiring, fuel composition sensor, mechanical
P0169 Incorrect fuel composition
fault
Intake leak, AIR system, fuel pressure/pump,
P0170 Fuel trim (FT), bank 1 - malfunction
injector(s), EVAP canister purge valve, HO2S
Intake/exhaust leak, AIR system, MAF/VAF
P0171 System too lean, bank 1
sensor, fuel pressure/pump, injector(s), HO2S
Intake blocked, EVAP canister purge valve,
P0172 System too rich, bank 1
fuel pressure, EGR system, injector(s), HO2S
P0173 Fuel trim (FT), bank 2 - malfunction
Intake/exhaust leak, fuel pressure/pump,
P0174 System too lean, bank 2
injector(s), AIR system, hose connection(s) injector(s), EVAP canister purge valve, HO2S
P0175 System too rich, bank 2
P0176 Fuel composition sensor - circuit malfunction Wiring, fuel composition sensor, ECM
Fuel composition sensor - range/performance
P0177 Fuel composition sensor
problem
Wiring short to earth, fuel composition sensor,
P0178 Fuel composition sensor - low input
ECM
Wiring short to positive, fuel composition
P0179 Fuel composition sensor - high input
sensor, ECM
P0180 Fuel temperature sensor A - circuit malfunction Wiring, fuel temperature sensor, ECM
Fuel temperature sensor A - range/performance
P0181 Fuel temperature sensor
problem
Wiring short to earth, fuel temperature sensor,
P0182 Fuel temperature sensor A - low input
ECM
Wiring short to positive, fuel temperature
P0183 Fuel temperature sensor A - high input
sensor, ECM
Wiring, poor connection, fuel temperature
P0184 Fuel temperature sensor A - circuit intermittent
sensor, ECM
P0185 Fuel temperature sensor B - circuit malfunction Wiring, fuel temperature sensor, ECM
Fuel temperature sensor B - range/performance
P0186 Fuel temperature sensor
problem
P0187 Fuel temperature sensor B - low input
ECM
P0188 Fuel temperature sensor B - high input
sensor, ECM
P0189 Fuel temperature sensor B - circuit intermittent
sensor, ECM
Fuel rail pressure (FRP) sensor - circuit
P0190 Wiring, fuel rail pressure sensor, ECM
malfunction
malfunction
P0191 Wiring, FRP sensor
P0192 Fuel rail pressure (FRP) sensor - low input Wiring short to earth, FRP sensor
P0193 Fuel rail pressure (FRP) sensor - high input Wiring short to positive, FRP sensor
P0194 Wiring, poor connection, FRP sensor
intermittent
Engine oil temperature (EOT) sensor - circuit
P0195 Wiring, EOT sensor, ECM
malfunction
P0196 EOT sensor
P0197 Engine oil temperature (EOT) sensor - low input Wiring short to earth, EOT sensor
P0198 Engine oil temperature (EOT) sensor - high input Wiring short to positive, EOT sensor
P0199 Wiring, poor connection, EOT sensor, ECM
intermittent
P0200 Injector - circuit malfunction Wiring, injector, ECM
P0201 Injector 1 - circuit malfunction Wiring, injector, ECM
P0202 Injector 2 - circuit malfunction Wiring, injector, ECM
P0203 Injector 3 - circuit malfunction Wiring, injector, ECM
P0204 Injector 4 - circuit malfunction Wiring, injector, ECM
P0205 Injector 5 - circuit malfunction Wiring, injector, ECM
P0206 Injector 6 - circuit malfunction Wiring, injector, ECM
P0207 Injector 7 - circuit malfunction Wiring, injector, ECM
P0208 Injector 8 - circuit malfunction Wiring, injector, ECM
P0209 Injector 9 - circuit malfunction Wiring, injector, ECM
P0210 Injector 10 - circuit malfunction Wiring, injector, ECM
P0211 Injector 11 - circuit malfunction Wiring, injector, ECM
P0212 Injector 12 - circuit malfunction Wiring, injector, ECM
P0213 Cold start injector 1 - circuit malfunction Wiring, cold start injector, ECM
P0214 Cold start injector 2 - circuit malfunction Wiring, cold start injector, ECM
P0215 Fuel shut-off solenoid - circuit malfunction Wiring, fuel shut-off solenoid, ECM
Wiring, fuel injection timing control solenoid,
P0216 Fuel injection timing control - circuit malfunction
ECM
P0217 Engine over temperature condition
ECT sensor
P0218 Transmission over temperature condition Wiring, TFT sensor, ECM
P0219 Engine over speed condition Incorrect gear change
Throttle position (TP) sensor B/accelerator pedal
P0220 Wiring, TP/APP sensor, ECM
position (APP) sensor B - circuit malfunction
Throttle position (TP) switch B/accelerator pedal
P0220 Wiring, TP/APP switch, ECM
position (APP) switch B - circuit malfunction
P0221 position (APP) sensor B - range/performance Accelerator cable adjustment, TP/APP sensor
problem
P0221 position (APP) switch B - range/performance Accelerator cable adjustment, TP/APP switch
problem
P0222 Wiring short to earth, TP/APP sensor, ECM
position (APP) sensor B - low input
P0222 Wiring short to earth, TP/APP switch, ECM
position (APP) switch B - low input
P0223 Wiring short to positive, TP/APP sensor, ECM
position (APP) sensor B - high input
P0223 Wiring short to positive, TP/APP switch, ECM
position (APP) switch B - high input
P0224 Wiring, poor connection, TP/APP sensor, ECM
position (APP) sensor B - circuit intermittent
P0224 Wiring, poor connection, TP/APP switch, ECM
position (APP) switch B - circuit intermittent
Throttle position (TP) sensor C/accelerator pedal
P0225 Wiring, TP/APP sensor, ECM
position (APP) sensor C - circuit malfunction
Throttle position (TP) switch C/accelerator pedal
P0225 Wiring, TP/APP switch, ECM
position (APP) switch C - circuit malfunction
P0226 position (APP) sensor C - range/performance Accelerator cable adjustment, TP/APP sensor
problem
P0226 position (APP) switch C - range/performance Accelerator cable adjustment, TP/APP switch
problem
P0227 Wiring short to earth, TP/APP sensor, ECM
position (APP) sensor C - low input
P0227 Wiring short to earth, TP/APP switch, ECM
position (APP) switch C - low input
P0228 Wiring short to positive, TP/APP sensor, ECM
position (APP) sensor C - high input
P0228 Wiring short to positive, TP/APP switch, ECM
position (APP) switch C - high input
P0229 Wiring, poor connection, TP/APP sensor, ECM
position (APP) sensor C - circuit intermittent
P0229 Wiring, poor connection, TP/APP switch, ECM
position (APP) switch C - circuit intermittent
P0230 Fuel pump relay - circuit malfunction Wiring, fuel pump relay, ECM
P0231 Fuel pump relay - circuit low Wiring short to earth, fuel pump relay, ECM
P0232 Fuel pump relay - circuit high Wiring short to positive, fuel pump relay, ECM
P0233 Fuel pump relay - circuit intermittent Wiring, poor connection, fuel pump relay, ECM
Hose connection(s), wiring, TC wastegate
P0234 Engine boost condition - limit exceeded
regulating valve, TC wastegate
P0235 Engine boost condition - limit not reached
regulating valve, TC wastegate, TC
Manifold absolute pressure (MAP) sensor A, TC Intake/exhaust leak, hose connection(s), MAP
P0236
system - range/performance problem sensor
P0237 Wiring short to earth, MAP sensor, ECM
system - low input system - range/performance problem sensor
system - low input
P0238 Wiring short to positive, MAP sensor, ECM
system - high input
Manifold absolute pressure (MAP) sensor B, TC
P0239 Wiring, MAP sensor, ECM
system - circuit malfunction
Manifold absolute pressure (MAP) sensor B, TC Intake/exhaust leak, hose connection(s), MAP
P0240
P0241 Wiring short to earth, MAP sensor, ECM
system - low input
P0242 Wiring short to positive, MAP sensor, ECM
system - high input
Turbocharger (TC) wastegate regulating valve A -
P0243 Wiring, TC wastegate regulating valve, ECM
circuit malfunction
P0244 TC wastegate regulating valve
Turbocharger (TC) wastegate regulating valve A - Wiring short to earth, TC wastegate regulating
P0245
Turbocharger (TC) wastegate regulating valve A - Wiring short to positive, TC wastegate
P0246
Turbocharger (TC) wastegate regulating valve B -
P0247 Wiring, TC wastegate regulating valve, ECM
circuit malfunction
P0248
OK. The question is how do you get around a cut-&-paste block??
Answer:
You need to have Word installed on the computer.
Open up a blank Word document, nd minimise it into the taskbar.
Open up the item you want to cut-&-paste and hold down Alt+Ctrl and then press Print Screen once while holding them down. (This cuts the info into the volatile memory of the PC).
Then open up the blank document, and right click anywhere on the page and select PASTE from the drop-down menu.
What you've done is to snapshot the screen and paste it into the new doument as a picture of whatever was on the screen. This cannot be blocked.
Neat eh?
Gapman
