Gs300 Auto Transmission Problem
andrewtaylor
Check to see if the Fluid is red, if you see that it's even slightly coloured and you've got a burning smell from the fluid change it immediately, since you don't know when it was last changed, change it anyway!!
Also remember to use ONLY the Toyota ATF :).
