Dash Board Lights
Ish
Hello all,
I've had my Lexus for about 3 years now, so it's a little runned down now.
The lights on my dash (Looks like - 1)Back fog lights 2)Oil Light & 3) Hand brake light) have an intermittent fault. They some times stay on all the time, when they do the speedo stops working.
Any idea's of a fix or what is causing the problem. Plz help. :duh:
Hello all,
so you can't see paradise by the dashboard light anymore eh :D
if its intermittent could be a loose connection. The speedo clusters are plug and play aren't they if a plug is slightly out and all the contacts are on that side that would explain it.
I bet someone round here can tell you if they are as well ;)
Hello all,
Thanks, It's an IS200 Nothing added since I brought it (not from new) & my warrenty has expired almost as quick as my petrol does.
I'll get someone to look at the speedo plugs. :D
If anyone knows anymore then plz let me know. Thanks
